Einleitung
This guide will provide step by step instructions on how to replace a battery on a Samsung Galaxy Tab A 10.1 tablet.
Was du brauchst
Remove all external power and turn off the tablet.
Insert a plastic opening tool between the screen and rear casing.
Pry the screen and rear casing apart.
Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
Pull the ribbon cables out of the sockets.
Remove the ten 4mm Phillips #000 screws from the battery.
Use a plastic opening tool to pry up the battery.
Remove the battery.
4 weitere Personen haben diese Anleitung absolviert.
