Zum Hauptinhalt wechseln
Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement
Was du brauchst
  1. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Rear Case: Schritt 1, Bild 1 von 3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Rear Case: Schritt 1, Bild 2 von 3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Rear Case: Schritt 1, Bild 3 von 3
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: Schritt 2, Bild 2 von 2
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Motherboard: Schritt 3, Bild 1 von 3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Motherboard: Schritt 3, Bild 2 von 3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Motherboard: Schritt 3, Bild 3 von 3
    • Use the plastic opening tool to lift up the black ZIF (zero insertion force) connector.
    • Use your hands to pull the black cable out of its slot.
  4. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: Schritt 4, Bild 2 von 2
    • Use the plastic opening tool to lift the ZIF (zero insertion force) connector holding the ribbon cable.
    • Pull out the battery's ribbon cable.
  5. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: Schritt 5, Bild 2 von 2
    • Use the plastic opening tool to lift up the latch to the ribbon cable.
    • Remove the ribbon cable from the connector.
  6. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: Schritt 6, Bild 1 von 1
    • Remove the seven 4mm PH000 screws holding the motherboard in place.
  7. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: Schritt 7, Bild 1 von 1
    • Use the plastic opening tool to pry up the tab holding the motherboard in place.
  8. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: Schritt 8, Bild 1 von 3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: Schritt 8, Bild 2 von 3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: Schritt 8, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use the precision tweezers to remove the black plastic corner on top of the motherboard.
    • Use the plastic opening tool to pull the motherboard out of the case.
  9. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Charging Port: Schritt 9, Bild 1 von 2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Charging Port: Schritt 9, Bild 2 von 2
    Kaufen
    • Use a soldering iron to heat 4 spots of solder from the motherboard.
    • To learn more about soldering, check out iFixit's soldering technique guide.
    • Use precision tweezers to remove the charging port.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team S19-G2, Hoffman Spring 2017 Mitglied von USF Tampa, Team S19-G2, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G2
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 6,587
