Einleitung
If your display is showing any dead pixels or if the color of the images are off, you may need to replace the display of your device. Use this guide to replace the display in your device.
Was du brauchst
Place the plastic opening tool into the SD card slot or charge port.
Try in an upward motion until you see a separation between the tablet and back cover.
Work around the entire device by sliding the plastic opening tool around the rim.
After taking off the back cover, use a pair of tweezers to disconnect the two (T807) ribbons.
Remove the four screws holding down the battery using the Phillips #000 screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
