Einleitung
This guide shall detail and illustrate how to replace the charging port and headphone jack for a Samsung Galaxy Y in the situation of either part not working.
Was du brauchst
Use the blue plastic opening tool to pry the back-panel off of the device.
Use the screwdriver with a PH000 screwdriver head to remove the four 5mm screws located in the corner of the interior back panel.
Remove the SD card as well by sliding the card out of it's slot.
Use metal pry tool to separate the interior back panel from the interior hardware and screen.
Disconnect the orange motherboard connection, then remove interior hardware from the front screen display.
Use a Phillips #000 screwdriver to remove the five 2mm screws located in the corner of the silver protective panel.
If the motherboard is cracked or damaged, then replace with a new one.
Desolder the charging port and headphone jack connections.
Wait until the metal cools down to pull the pieces off.
Eine weitere Person hat diese Anleitung absolviert.
