Einleitung
Use this guide to replace a damaged front case or open the case to access other components of your camera.
Ersatzteile
Keine Ersatzteile angegeben.
Orient the camera so the button panel and LCD are facing you.
Use a spudger or fingernail to open the battery compartment on the right side of the camera.
Push the blue trapdoor to the left to release the battery, and remove the battery.
Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
