Zum Hauptinhalt wechseln
Samsung P241 Front Panel Replacement
Was du brauchst
  1. Samsung P241 Front Panel Replacement, Top Case: Schritt 1, Bild 1 von 2 Samsung P241 Front Panel Replacement, Top Case: Schritt 1, Bild 2 von 2
    • You will need to be near a power source for this guide.
    • With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
  2. Samsung P241 Front Panel Replacement: Schritt 2, Bild 1 von 2 Samsung P241 Front Panel Replacement: Schritt 2, Bild 2 von 2
    • Pull the top cover towards you until you can lift it up and off.
  3. Samsung P241 Front Panel Replacement, Front Panel: Schritt 3, Bild 1 von 2 Samsung P241 Front Panel Replacement, Front Panel: Schritt 3, Bild 2 von 2
    • With the front of the DVD player facing you, turn the power on and eject the disc tray.
    • Press down on the disc tray with your thumbs while also pressing up with your pointer finger on the left and right edges of the silver cover. The cover should easily pop up and off the disc tray.
    • Be careful not to crack or bend the disc tray by pulling too hard.
  4. Samsung P241 Front Panel Replacement: Schritt 4, Bild 1 von 3 Samsung P241 Front Panel Replacement: Schritt 4, Bild 2 von 3 Samsung P241 Front Panel Replacement: Schritt 4, Bild 3 von 3
    • To remove the front panel, lift up the clips on the bottom, left and right sides of the DVD player.
    • Be sure to have all clips lifted up at the same time otherwise it will be difficult to get the panel off.
    • If you are having trouble removing the panel, try wedging an object underneath the two clips on the bottom to keep them from falling back into place.
  5. Samsung P241 Front Panel Replacement: Schritt 5, Bild 1 von 1
    • Gently remove the front panel by pulling it forward.
  6. Samsung P241 Front Panel Replacement: Schritt 6, Bild 1 von 1
    • Press the eject button again to make the disc tray slide back into place.
    • Turn off the DVD player and unplug it from the wall before proceeding to further steps.
Abschluss
Cal Poly, Team 14-7, Forte Winter 2011 Mitglied von Cal Poly, Team 14-7, Forte Winter 2011
CPSU-FORTE-W11S14G7
5 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 8
Insgesamt: 839
