Einleitung
Wi-Fi card replacement may be done when the Wi-Fi card is suspected to be damaged. Take a look at the troubleshooting page before starting this guide to review the typical issues.
Was du brauchst
Locate two notches above the battery.
Slide both battery locking notches to either side to remove the battery.
Pull the battery out.
Using the Phillips #0 screwdriver, unscrew the one 5mm screw.
Using the blue plastic opening tools, wedge one in between the back panel and the laptop.
Carefully remove the back panel..
Use the spudger or fingers to gently pull the optical drive out.
Slide the optic drive away from the laptop.
Remove the eight 5mm Phillips #0 screws using a Phillips #0 driver.
Also remove the three 5mm Phillips #0 using a Phillips #0 driver.
Remove three bottom dark covers using tweezers.
Remove three 10mm Phillips #0 screws using Phillips #0 driver.
Insert a plastic opening tool into the back cover and the housing of the body.
Use the plastic opening tool to pop open the clamps that hold the casing onto the back cover.
Work your way around the all sides to completely take off the back cover.
Remove one 5mm Phillips #0 screw using a Phillips #0 driver.
The Wi-Fi card will rise up itself after removing the Phillips #0 screw. Pull it out away from the slot.
