Zum Hauptinhalt wechseln
Samsung RC512 Wi-Fi Card Replacement
Was du brauchst
  1. Samsung RC512 Wi-Fi Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the laptop upside down.
  2. Samsung RC512 Wi-Fi Card Replacement: Schritt 2, Bild 1 von 2 Samsung RC512 Wi-Fi Card Replacement: Schritt 2, Bild 2 von 2
    • Locate two notches above the battery.
    • Slide both battery locking notches to either side to remove the battery.
    • Pull the battery out.
  3. Samsung RC512 Wi-Fi Card Replacement, Back Panel: Schritt 3, Bild 1 von 3 Samsung RC512 Wi-Fi Card Replacement, Back Panel: Schritt 3, Bild 2 von 3 Samsung RC512 Wi-Fi Card Replacement, Back Panel: Schritt 3, Bild 3 von 3
    • Using the Phillips #0 screwdriver, unscrew the one 5mm screw.
    • Using the blue plastic opening tools, wedge one in between the back panel and the laptop.
    • Carefully remove the back panel..
  4. Samsung RC512 Wi-Fi Card Replacement, HDD: Schritt 4, Bild 1 von 1
    • Carefully lift the HDD up using plastic opening tool.
  5. Samsung RC512 Wi-Fi Card Replacement: Schritt 5, Bild 1 von 1
    • Grab the HDD and connector.
    • Carefully pull the HDD away from the connector.
  6. Samsung RC512 Wi-Fi Card Replacement: Schritt 6, Bild 1 von 1
    • Take out the HDD and leave the connector in the laptop
  7. Samsung RC512 Wi-Fi Card Replacement, Optic Drive: Schritt 7, Bild 1 von 1
    • Remove the 4mm Phillips #0 screw using a Phillips #0 screwdriver.
  8. Samsung RC512 Wi-Fi Card Replacement: Schritt 8, Bild 1 von 3 Samsung RC512 Wi-Fi Card Replacement: Schritt 8, Bild 2 von 3 Samsung RC512 Wi-Fi Card Replacement: Schritt 8, Bild 3 von 3
    • Use the spudger or fingers to gently pull the optical drive out.
    • Slide the optic drive away from the laptop.
  9. Samsung RC512 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 9, Bild 1 von 2 Samsung RC512 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 9, Bild 2 von 2
    • Remove the eight 5mm Phillips #0 screws using a Phillips #0 driver.
    • Also remove the three 5mm Phillips #0 using a Phillips #0 driver.
  10. Samsung RC512 Wi-Fi Card Replacement: Schritt 10, Bild 1 von 3 Samsung RC512 Wi-Fi Card Replacement: Schritt 10, Bild 2 von 3 Samsung RC512 Wi-Fi Card Replacement: Schritt 10, Bild 3 von 3
    • Remove three bottom dark covers using tweezers.
    • Remove three 10mm Phillips #0 screws using Phillips #0 driver.
  11. Samsung RC512 Wi-Fi Card Replacement: Schritt 11, Bild 1 von 2 Samsung RC512 Wi-Fi Card Replacement: Schritt 11, Bild 2 von 2
    • Insert a plastic opening tool into the back cover and the housing of the body.
    • Use the plastic opening tool to pop open the clamps that hold the casing onto the back cover.
    • Work your way around the all sides to completely take off the back cover.
    • You may use your fingers to help remove the cover.
    • Carefully lift the back cover. Do not use excessive force to lift it. If it feels like it will not pull up, make sure all the screws have been taken out.
  12. Samsung RC512 Wi-Fi Card Replacement: Schritt 12, Bild 1 von 3 Samsung RC512 Wi-Fi Card Replacement: Schritt 12, Bild 2 von 3 Samsung RC512 Wi-Fi Card Replacement: Schritt 12, Bild 3 von 3
    • Gently lift the connectors from the Wi-Fi card.
  13. Samsung RC512 Wi-Fi Card Replacement: Schritt 13, Bild 1 von 2 Samsung RC512 Wi-Fi Card Replacement: Schritt 13, Bild 2 von 2
    • Remove one 5mm Phillips #0 screw using a Phillips #0 driver.
    • The Wi-Fi card will rise up itself after removing the Phillips #0 screw. Pull it out away from the slot.
Abschluss
jando
896 Reputation
8 Anleitungen geschrieben
USF Tampa, Team 18-2, Blackwell Fall 2016 Mitglied von USF Tampa, Team 18-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G2
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 597
