Zum Hauptinhalt wechseln
Samsung RF28R7201SG Refrigerator Fuse Block Replacement
Was du brauchst
  1. Samsung RF28R7201SG Refrigerator Fuse Block Replacement, Unplug your refrigerator: Schritt 1, Bild 1 von 1
    • Unplug your refrigerator before you begin your repair.
    Frag FixBot
    Kommentar hinzufügen
  2. Samsung RF28R7201SG Refrigerator Fuse Block Replacement, Remove the board access panel: Schritt 2, Bild 1 von 1
    • Use a Phillips screwdriver to remove the five screws securing the board access panel to the back of the refrigerator:
    • Four 14.8 mm-long screws
    • One 12.3 mm-long screw
    Frag FixBot
  3. Samsung RF28R7201SG Refrigerator Fuse Block Replacement: Schritt 3, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Fuse Block Replacement: Schritt 3, Bild 2 von 2
    • Remove the board access panel.
    Frag FixBot
  4. Samsung RF28R7201SG Refrigerator Fuse Block Replacement, Remove the fuse block: Schritt 4, Bild 1 von 3 Samsung RF28R7201SG Refrigerator Fuse Block Replacement, Remove the fuse block: Schritt 4, Bild 2 von 3 Samsung RF28R7201SG Refrigerator Fuse Block Replacement, Remove the fuse block: Schritt 4, Bild 3 von 3
    • Squeeze the wide sides of the red connector to unlatch it from the fuse block.
    • Pull to disconnect the connector.
    • Repeat the procedure to disconnect the blue connector.
    • During reassembly, make sure the connectors lock in place. If they don't, you may need to flip their orientation.
    Frag FixBot
  5. Samsung RF28R7201SG Refrigerator Fuse Block Replacement: Schritt 5, Bild 1 von 3 Samsung RF28R7201SG Refrigerator Fuse Block Replacement: Schritt 5, Bild 2 von 3 Samsung RF28R7201SG Refrigerator Fuse Block Replacement: Schritt 5, Bild 3 von 3
    • Use your fingers to pry and release the black plastic clip holding the left edge of the fuse block.
    • Lift out and remove the fuse block.
    Frag FixBot
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
2 weitere Personen haben diese Anleitung absolviert.
nicO
15.990 Reputation
89 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 48
Insgesamt: 607
