Zum Hauptinhalt wechseln
Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement
Was du brauchst
  1. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unplug your refrigerator: Schritt 1, Bild 1 von 1
    • Unplug your refrigerator before you begin your repair.
    Frag FixBot
    Kommentar hinzufügen
  2. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: Schritt 2, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: Schritt 2, Bild 2 von 2
    • Open both French doors for the refrigerator compartment.
    Frag FixBot
  3. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the ice tray: Schritt 3, Bild 1 von 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the ice tray: Schritt 3, Bild 2 von 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the ice tray: Schritt 3, Bild 3 von 3
    • Pull the ice tray straight out of its housing and remove it.
    Frag FixBot
  4. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: Schritt 4, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: Schritt 4, Bild 2 von 2
    • Use a Phillips screwdriver to remove the 16.5 mm‑long screw securing the cable cover panel.
    Frag FixBot
  5. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: Schritt 5, Bild 1 von 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: Schritt 5, Bild 2 von 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: Schritt 5, Bild 3 von 3
    • Use your fingers to slide the cable cover panel towards the front of the refrigerator to unlatch it.
    • Remove the cable cover panel.
    • During reassembly, make sure this panel clips fully in place, or the ice tray won't slide in properly.
    Frag FixBot
  6. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: Schritt 6, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: Schritt 6, Bild 2 von 2
    • Disconnect the left-most yellow connector:
    • Squeeze the locking tab with the red mark with your fingers
    • Rock the connector gently side to side to disconnect it
    • Use your fingers or a screwdriver to guide the wire harness out of the wall clips.
    Frag FixBot
  7. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unfasten the air tunnel: Schritt 7, Bild 1 von 1
    • Use a Phillips screwdriver to remove the 16.5 mm-long screw securing the air tunnel flap.
    Frag FixBot
  8. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: Schritt 8, Bild 1 von 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: Schritt 8, Bild 2 von 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: Schritt 8, Bild 3 von 3
    • A plastic clip holds the air tunnel flap in place.
    • Use a flathead screwdriver to pry and loosen the air tunnel flap from the plastic clip.
    Frag FixBot
  9. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 9, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 9, Bild 2 von 2
    • Use your fingers to pull the air tunnel flap down enough to access the internals.
    Frag FixBot
  10. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 10, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 10, Bild 2 von 2
    • Use a flathead screwdriver to gently pry the refrigerant loop down by 1–1.5 cm.
    • During reassembly, use your fingers to push the refrigerant loop back up.
    Frag FixBot
  11. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 11, Bild 1 von 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 11, Bild 2 von 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 11, Bild 3 von 3
    • A plastic clip holds the icemaker in place.
    • Use your fingers to press and release the plastic clip.
    • This clip is stiff and may require substantial force.
    Frag FixBot
  12. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 12, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 12, Bild 2 von 2
    • Pull the front edge of the icemaker assembly down slightly to loosen it.
    • Be careful not to bend the refrigerant loop too much as you pull the front edge, or you'll damage the loop.
    • Carefully slide the icemaker assembly out of its housing.
    Frag FixBot
  13. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 13, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 13, Bild 2 von 2
    Frag FixBot
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15.990 Reputation
89 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 82
Letzte 30 Tage: 316
Insgesamt: 3,879
