Zum Hauptinhalt wechseln
Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement
Was du brauchst
  1. Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement, Unplug your refrigerator: Schritt 1, Bild 1 von 1
    • Unplug your refrigerator before you begin your repair.
    Frag FixBot
    Kommentar hinzufügen
  2. Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement, Remove the hinge cover: Schritt 2, Bild 1 von 1
    • Use a Phillips screwdriver to remove the three 18.5 mm-long screws securing the hinge cover on the top of the refrigerator.
    Frag FixBot
  3. Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement: Schritt 3, Bild 1 von 1
    • Lift the edges of the hinge cover to loosen it from the refrigerator.
    • Don't try to fully remove the cover, as it's still attached to the refrigerator by a few cables.
    • Flip the hinge cover over to access the cables underneath.
    Frag FixBot
  4. Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement: Schritt 4, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement: Schritt 4, Bild 2 von 2
    • Use your fingers to squeeze and disconnect the blue wire connector.
    • Use your fingers to squeeze and disconnect the white wire connector.
    Frag FixBot
  5. Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement: Schritt 5, Bild 1 von 1
    • Remove the hinge cover.
    Frag FixBot
  6. Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement, Remove the Wi-Fi card: Schritt 6, Bild 1 von 3 Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement, Remove the Wi-Fi card: Schritt 6, Bild 2 von 3 Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement, Remove the Wi-Fi card: Schritt 6, Bild 3 von 3
    • The Wi-Fi card is attached to the hinge cover.
    • Use your fingers to squeeze and slide the Wi-Fi cable connector out of its socket.
    Frag FixBot
  7. Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement: Schritt 7, Bild 1 von 1
    • Use a Phillips screwdriver to remove the two 9.7 mm-long screws securing the Wi-Fi card to the hinge cover.
    Frag FixBot
  8. Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement: Schritt 8, Bild 1 von 1
    • Lift and remove the Wi-Fi card.
    Frag FixBot
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15.990 Reputation
89 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 36
Insgesamt: 492
