Zum Hauptinhalt wechseln
Samsung Refrigerator Evaporator Drain Clip Replacement
Was du brauchst
    1. Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: Schritt 1, Bild 1 von 3 Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: Schritt 1, Bild 2 von 3 Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: Schritt 1, Bild 3 von 3
      • Using a spudger, pry off the cap covering the topmost screw.
      Frag FixBot
      Kommentar hinzufügen
    2. Samsung Refrigerator Evaporator Drain Clip Replacement: Schritt 2, Bild 1 von 3 Samsung Refrigerator Evaporator Drain Clip Replacement: Schritt 2, Bild 2 von 3 Samsung Refrigerator Evaporator Drain Clip Replacement: Schritt 2, Bild 3 von 3
      • Remove three 12.7 mm screws using a Phillips #0 screwdriver.
      Frag FixBot
    3. Samsung Refrigerator Evaporator Drain Clip Replacement: Schritt 3, Bild 1 von 3 Samsung Refrigerator Evaporator Drain Clip Replacement: Schritt 3, Bild 2 von 3 Samsung Refrigerator Evaporator Drain Clip Replacement: Schritt 3, Bild 3 von 3
      • Use your hands or a spudger to pry back the plastic cover starting from the bottom.
      • Once all the clips are pulled out, loosen the cover by pushing it slightly up and out.
      • Do not pull the cover off yet; there are still connectors attaching the cover to the fridge.
      Frag FixBot
    4. Samsung Refrigerator Evaporator Drain Clip Replacement: Schritt 4, Bild 1 von 3 Samsung Refrigerator Evaporator Drain Clip Replacement: Schritt 4, Bild 2 von 3 Samsung Refrigerator Evaporator Drain Clip Replacement: Schritt 4, Bild 3 von 3
      • Gently unplug both connectors.
      • Remember their orientations as it will be important during reassembly.
      Frag FixBot
    5. Samsung Refrigerator Evaporator Drain Clip Replacement: Schritt 5, Bild 1 von 1
      • Using a hair dryer or heat gun, melt down any ice buildup in the draining well.
      Frag FixBot
    6. Samsung Refrigerator Evaporator Drain Clip Replacement: Schritt 6, Bild 1 von 1
      • Cut out the old evaporating clip using a pair of cutting pliers.
      Frag FixBot
    7. Samsung Refrigerator Evaporator Drain Clip Replacement: Schritt 7, Bild 1 von 3 Samsung Refrigerator Evaporator Drain Clip Replacement: Schritt 7, Bild 2 von 3 Samsung Refrigerator Evaporator Drain Clip Replacement: Schritt 7, Bild 3 von 3
      • Replace the old clip with a new evaporating clip.
      Frag FixBot
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
York University, Team S3-G60, Melo-Thaiss Fall 2020 Mitglied von York University, Team S3-G60, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S3G60
1 Mitglied
3 Anleitungen geschrieben
3 Kommentare zur Anleitung
you rock!!!@
Marie Przehorski - Antwort Teilen
Problem only resolved for about 6 months post clip replacement. Now every 2 months back to defrosting my refrigerator, under the crisper drawer. Now the entire section of the drain is frozen. Very frustraing.
David Kahan - Antwort Teilen
Here's another video of this replacement. Head over to the refrigerator leaking water wiki for more fixes for freezing lines.
nicO - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 14
Letzte 7 Tage: 176
Letzte 30 Tage: 741
Insgesamt: 26,273
