Zum Hauptinhalt wechseln
Samsung Series 5 Ultrabook Speakers Replacement
Was du brauchst
  1. Samsung Series 5 Ultrabook Speakers Replacement, Remove the Screws on the Back Cover: Schritt 1, Bild 1 von 2 Samsung Series 5 Ultrabook Speakers Replacement, Remove the Screws on the Back Cover: Schritt 1, Bild 2 von 2
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
  2. Samsung Series 5 Ultrabook Speakers Replacement, Remove the Rubber Pads: Schritt 2, Bild 1 von 2 Samsung Series 5 Ultrabook Speakers Replacement, Remove the Rubber Pads: Schritt 2, Bild 2 von 2
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 Ultrabook Speakers Replacement, Remove the Back Cover: Schritt 3, Bild 1 von 2 Samsung Series 5 Ultrabook Speakers Replacement, Remove the Back Cover: Schritt 3, Bild 2 von 2
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 Ultrabook Speakers Replacement: Schritt 4, Bild 1 von 2 Samsung Series 5 Ultrabook Speakers Replacement: Schritt 4, Bild 2 von 2
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 Ultrabook Speakers Replacement: Schritt 5, Bild 1 von 1
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 Ultrabook Speakers Replacement, Remove the Battery: Schritt 6, Bild 1 von 1
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 Ultrabook Speakers Replacement: Schritt 7, Bild 1 von 1
    • Remove the battery from the laptop.
Abschluss
Javier Jimenez
223 Reputation
2 Anleitungen geschrieben
IUPUI, Team S1-G6, Harley Fall 2019 Mitglied von IUPUI, Team S1-G6, Harley Fall 2019
IUPUI-HARLEY-F19S1G6
3 Mitglieder
Ein Kommentar
And about removing speakers?
Rodrigo Melo - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 741
