Zum Hauptinhalt wechseln
Samsung SmartThings Hub USB Port Replacement
Was du brauchst
  1. Samsung SmartThings Hub USB Port Replacement, USB Port: Schritt 1, Bild 1 von 1
    • To open your device, gently slide the grey bottom cover in the direction of the arrow as shown.
  2. Samsung SmartThings Hub USB Port Replacement: Schritt 2, Bild 1 von 3 Samsung SmartThings Hub USB Port Replacement: Schritt 2, Bild 2 von 3 Samsung SmartThings Hub USB Port Replacement: Schritt 2, Bild 3 von 3
    • Make sure the batteries are removed before attempting disassembly.
    • Using your Phillips #1 screwdriver, remove the four visible 12.5mm screws.
    • Next, either peel up the longer of the two stickers or punch a hole with the tip of your screwdriver to access the fifth 12.5mm screw.
  3. Samsung SmartThings Hub USB Port Replacement: Schritt 3, Bild 1 von 3 Samsung SmartThings Hub USB Port Replacement: Schritt 3, Bild 2 von 3 Samsung SmartThings Hub USB Port Replacement: Schritt 3, Bild 3 von 3
    • Once all five screws are removed, split the casing apart by applying gentle upwards pressure against the positive terminals in the battery compartment.
  4. Samsung SmartThings Hub USB Port Replacement: Schritt 4, Bild 1 von 2 Samsung SmartThings Hub USB Port Replacement: Schritt 4, Bild 2 von 2
    • To remove the motherboard, grip the USB port and the Ethernet port. Lift up, then slide towards the front of the device to release the motherboard from the black retaining clip shown on the right.
  5. Samsung SmartThings Hub USB Port Replacement: Schritt 5, Bild 1 von 3 Samsung SmartThings Hub USB Port Replacement: Schritt 5, Bild 2 von 3 Samsung SmartThings Hub USB Port Replacement: Schritt 5, Bild 3 von 3
    • Place the motherboard on a clean, flat surface.
    • Preheat your soldering iron. Each USB port has eight points of connection to the motherboard (pictured above). Using your soldering iron, apply heat to each solder joint in turn while pulling the USB port away from the board.
    • Soldering irons can reach temperatures of over 500 degrees. Watch your fingers!
    • For more information on soldering refer to How To Solder and Desolder Connections.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Erin
485 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 725
