Zum Hauptinhalt wechseln
Samsung WB1100F Camera Flash Replacement
Was du brauchst
  1. Samsung WB1100F Camera Flash Replacement, LCD Screen Cover: Schritt 1, Bild 1 von 2 Samsung WB1100F Camera Flash Replacement, LCD Screen Cover: Schritt 1, Bild 2 von 2
    • Remove six 1.2 mm Phillips #00 screws connected to the tripod dock and adjacent screws.
    • Remove six 1.2 mm Phillips #00 screws from the side of the camera.
  2. Samsung WB1100F Camera Flash Replacement: Schritt 2, Bild 1 von 2 Samsung WB1100F Camera Flash Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool or spudger if available.
    • Using the flat end of a spudger, loosen the connection between the back panel and the device. Remove the back panel using your hands.
  3. Samsung WB1100F Camera Flash Replacement, Camera Flash: Schritt 3, Bild 1 von 3 Samsung WB1100F Camera Flash Replacement, Camera Flash: Schritt 3, Bild 2 von 3 Samsung WB1100F Camera Flash Replacement, Camera Flash: Schritt 3, Bild 3 von 3
    • Remove four 1.2 mm Phillips #00 screws from the top panel.
  4. Samsung WB1100F Camera Flash Replacement: Schritt 4, Bild 1 von 1
    • Using the flat end of a spudger, loosen the connection between the top panel and the device. Remove the top panel using your hands.
  5. Samsung WB1100F Camera Flash Replacement: Schritt 5, Bild 1 von 1
    • Remove four 1.2 mm Phillips #00 screws from the flash assembly
  6. Samsung WB1100F Camera Flash Replacement: Schritt 6, Bild 1 von 1
    • Using your hands, remove the flash assembly. This should not require much force.
  7. Samsung WB1100F Camera Flash Replacement: Schritt 7, Bild 1 von 2 Samsung WB1100F Camera Flash Replacement: Schritt 7, Bild 2 von 2
    • Using your hands, remove the top flash panel by pressuring down on the back to release a locking tab.
  8. Samsung WB1100F Camera Flash Replacement: Schritt 8, Bild 1 von 1
    • Desolder three wires on the flash assembly.
  9. Samsung WB1100F Camera Flash Replacement: Schritt 9, Bild 1 von 1
    • Gently remove the flash assembly from the body.
Abschluss
Jesse Lindsey
581 Reputation
5 Anleitungen geschrieben
Metro State, Team 1-1, Carpenter SU 2016 Mitglied von Metro State, Team 1-1, Carpenter SU 2016
MSU-CARPENTER-SU16S1G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 582
