Einleitung
This guide provides instructions on how to replace the flash component of the Samsung WB1100F.
Was du brauchst
Remove six 1.2 mm Phillips #00 screws connected to the tripod dock and adjacent screws.
Remove six 1.2 mm Phillips #00 screws from the side of the camera.
Using the flat end of a spudger, loosen the connection between the back panel and the device. Remove the back panel using your hands.
Using the flat end of a spudger, loosen the connection between the top panel and the device. Remove the top panel using your hands.
Using your hands, remove the flash assembly. This should not require much force.
Using your hands, remove the top flash panel by pressuring down on the back to release a locking tab.
