Zum Hauptinhalt wechseln
Sanyo VPC S1275 Flash Mechanism Replacement
Was du brauchst
  1. Sanyo VPC S1275 Flash Mechanism Replacement, Case: Schritt 1, Bild 1 von 3 Sanyo VPC S1275 Flash Mechanism Replacement, Case: Schritt 1, Bild 2 von 3 Sanyo VPC S1275 Flash Mechanism Replacement, Case: Schritt 1, Bild 3 von 3
    • Remove the following six screws using the Phillips #00 screwdriver:
    • Two screws on the left side of the camera.
    • Two screws on the right side of the camera.
    • Two screws on the bottom of the camera.
  2. Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 2, Bild 1 von 2 Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 2, Bild 2 von 2
    • Open the battery slot on the bottom of the camera by sliding the door to the right.
    • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
  3. Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 3, Bild 1 von 3 Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 3, Bild 2 von 3 Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 3, Bild 3 von 3
    • Insert a spudger in the seam at the bottom of the camera.
    • Gently separate the rear case from the front of the camera.
  4. Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 4, Bild 1 von 1
    • This step is only needed for the case and logic board replacement
    • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
  5. Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 5, Bild 1 von 1
    • This step is only needed for the case replacement.
    • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
    • Slide the battery door off of the hinge.
  6. Sanyo VPC S1275 Flash Mechanism Replacement, LCD Screen: Schritt 6, Bild 1 von 2 Sanyo VPC S1275 Flash Mechanism Replacement, LCD Screen: Schritt 6, Bild 2 von 2
    • Using the spudger, carefully lift up the LCD screen, making sure to keep the ribbon cable intact.
    • Place the LCD screen on a non-abrasive surface.
  7. Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 7, Bild 1 von 1
    • Using the spudger lift the black flap up to release the ribbon cable.
    • The LCD screen will now be completely detached from the camera.
  8. Sanyo VPC S1275 Flash Mechanism Replacement, Logic Board: Schritt 8, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the four screws on the outer edge of the LCD holding plate.
  9. Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 9, Bild 1 von 1
    • Be careful when rotating the plate in the next step to prevent the ribbon cable in the top right from ripping.
    • Using your right hand, grab the left side of the LCD holding plate and rotate it to the right.
  10. Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 10, Bild 1 von 1
    • Remove the ribbon cable from its slot by gently pulling the LCD holding plate to the right.
  11. Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 11, Bild 1 von 2 Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 11, Bild 2 von 2
    • Do not touch ANY part of the logic board previously covered by the black film until the capacitor has been completely discharged. This camera has a 330V, 100 µF capacitor which can cause painful electric shock.
    • Using the spudger (or any non-metal prying tool), gently remove the black film.
  12. Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 12, Bild 1 von 1
    • Using the capacitor discharge tool carefully touch each end of the capacitor discharge tool to the each terminal of the capacitor.
    • Click the link below for instructions on how to make the capacitor discharge tool: Ein Entladewerkzeug für Kondensatoren im Eigenbau
    • NEVER touch both both capacitor terminals with just one of the wires. This will create a potentially dangerous large spark. This will also cause serious damage to the camera.
    • Keep the wires connected to the capacitor terminals for 2 minutes to completely discharge the capacitor.
    • The camera should be completely safe to handle now.
  13. Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 13, Bild 1 von 1
    • Touch the hot tip of the solding iron to the first solder connecting the flash mechanism to the logic board until the solder melts.
    • Repeat this for the next 10 solders.
    • Verify solders have detached logic board.
  14. Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 14, Bild 1 von 1
    • Touch the hot soldering iron to the solder in the lower left corner connecting the logic board to the red wire.
    • When the solder has completely melted, gently pull the wire free from the logic board.
    • Repeat for the red, blue, and then black wires.
  15. Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 15, Bild 1 von 2 Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 15, Bild 2 von 2
    • Touch the soldering iron tip to the solder in the upper right corner connecting the logic board to the battery lead.
    • Pull the battery lead out of the slot in the logic board. This must be done immeadiately after the solder melts.
    • Repeat for the solder to the left.
    • The logic board will now be completely free from the camera.
  16. Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 16, Bild 1 von 1
    • Insert the battery leads into the slots in the new logic board.
    • Solder both leads to the logic board.
  17. Sanyo VPC S1275 Flash Mechanism Replacement, Flash Mechanism: Schritt 17, Bild 1 von 1
    • Remove screw from top of the flash mechanism
  18. Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 18, Bild 1 von 1
    • Remove the flash bulb from the camera housing by gently pulling on the wires with a pair of tweezers.
  19. Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 19, Bild 1 von 1
    • Poke the capacitor out of its housing with the spudger.
  20. Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 20, Bild 1 von 2 Sanyo VPC S1275 Flash Mechanism Replacement: Schritt 20, Bild 2 von 2
    • Break the tabs on the camera housing that hold the flash logic board.
    • Lift up on the logic board. The capacitor and the flash bulb will be removed as well.
Abschluss
Evan Perez
19 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 24-24, Regan Spring 2010 Mitglied von Cal Poly, Team 24-24, Regan Spring 2010
CPSU-REGAN-S10S24G24
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 18
Letzte 30 Tage: 18
Insgesamt: 3,027
