Zum Hauptinhalt wechseln
Scuf Instinct Pro Thumbstick Covers Replacement
  1. Scuf Instinct Pro Thumbstick Covers Replacement, Prepare your controller for disassembly: Schritt 1, Bild 1 von 1
    • Unplug all cables from your controller before starting.
    • Completely power off your controller.
    Frag FixBot
  2. Scuf Instinct Pro Thumbstick Covers Replacement, Remove the faceplate: Schritt 2, Bild 1 von 3 Scuf Instinct Pro Thumbstick Covers Replacement, Remove the faceplate: Schritt 2, Bild 2 von 3 Scuf Instinct Pro Thumbstick Covers Replacement, Remove the faceplate: Schritt 2, Bild 3 von 3
    • Magnets secure the faceplace to the midframe.
    • Lift the top edge of the faceplate to release the magnets securing it.
    • Remove the faceplate.
    Frag FixBot
  3. Scuf Instinct Pro Thumbstick Covers Replacement, Remove the thumbstick covers: Schritt 3, Bild 1 von 3 Scuf Instinct Pro Thumbstick Covers Replacement, Remove the thumbstick covers: Schritt 3, Bild 2 von 3 Scuf Instinct Pro Thumbstick Covers Replacement, Remove the thumbstick covers: Schritt 3, Bild 3 von 3
    • Firmly secure the controller with one hand, and use your other hand to lift the thumbstick covers straight off their modules.
    • This requires significant force. If you're having trouble, try wiggling the cover to help loosen it.
    • To install a thumbstick cover:
    • Place and rotate the cover on its module until it slides into place.
    • Firmly press down on the cover until it snaps into place or bottoms out.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Spencer Day
188.903 Reputation
1.187 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.805 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 71
Insgesamt: 1,918
