Zum Hauptinhalt wechseln
Set-Top Box Numb Button Replacement
Was du brauchst
  1. Set-Top Box Numb Button Replacement, Numb Button: Schritt 1, Bild 1 von 3 Set-Top Box Numb Button Replacement, Numb Button: Schritt 1, Bild 2 von 3 Set-Top Box Numb Button Replacement, Numb Button: Schritt 1, Bild 3 von 3
    • Make sure the box is not plugged in before starting!
    • Remove the 5 screws holding the outer casing in place: 3 can be found on the back and 1 on either side of the box.
    • Slide the casing backwards.
  2. Set-Top Box Numb Button Replacement: Schritt 2, Bild 1 von 3 Set-Top Box Numb Button Replacement: Schritt 2, Bild 2 von 3 Set-Top Box Numb Button Replacement: Schritt 2, Bild 3 von 3
    • Disconnect the front of the by lifting the 2 connectors . You can also apply extra pressure on the front from below.
    • Tilt the front forward and remove it.
    • Remove the connector by pressing the upper part of it and carefully pulling it.
    • Be carefull not to damage the cables and circuit board!
  3. Set-Top Box Numb Button Replacement: Schritt 3, Bild 1 von 3 Set-Top Box Numb Button Replacement: Schritt 3, Bild 2 von 3 Set-Top Box Numb Button Replacement: Schritt 3, Bild 3 von 3
    • Undo the 4 screws of the front panel.
    • Locate your broken button. For instance, the third button from the left (front view), is the CH- button.
  4. Set-Top Box Numb Button Replacement: Schritt 4, Bild 1 von 3 Set-Top Box Numb Button Replacement: Schritt 4, Bild 2 von 3 Set-Top Box Numb Button Replacement: Schritt 4, Bild 3 von 3
Abschluss
Yvo Kipping
101 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 427
