Zum Hauptinhalt wechseln
Sew a Ladder Stitch
Was du brauchst
  1. Sew a Ladder Stitch, Sew a Ladder Stitch: Schritt 1, Bild 1 von 3 Sew a Ladder Stitch, Sew a Ladder Stitch: Schritt 1, Bild 2 von 3 Sew a Ladder Stitch, Sew a Ladder Stitch: Schritt 1, Bild 3 von 3
    • Thread your needle and tie a knot in the end.
    • We're using contrasting thread for visibility, but when it comes time for your repair, you'll want to use matching thread.
    • Drive the needle from the back of the material, just before where the tear starts.
    • Pull the thread taut.
    Frag FixBot
  2. Sew a Ladder Stitch: Schritt 2, Bild 1 von 2 Sew a Ladder Stitch: Schritt 2, Bild 2 von 2
    • Take a small stitch, going in and out of the material, on one side of the tear only.
    Frag FixBot
  3. Sew a Ladder Stitch: Schritt 3, Bild 1 von 2 Sew a Ladder Stitch: Schritt 3, Bild 2 von 2
    • Take a small stitch, going in and out of the material, on the other side of the tear, directly opposite of the stitch you just took.
    • Pull the thread taut. This should cinch the material together.
    • If your material bunches, try taking smaller stitches, while ensuring that you line up the stitches on either side of the material.
    Frag FixBot
  4. Sew a Ladder Stitch: Schritt 4, Bild 1 von 2 Sew a Ladder Stitch: Schritt 4, Bild 2 von 2
    • Continue stitching, switching from side to side as described in step 2 and 3 of this guide, pulling the thread taut after each stitch.
    • Stitch until you come to the end of the tear.
    Frag FixBot
  5. Sew a Ladder Stitch: Schritt 5, Bild 1 von 3 Sew a Ladder Stitch: Schritt 5, Bild 2 von 3 Sew a Ladder Stitch: Schritt 5, Bild 3 von 3
    • One the last stitch, drive the needle through both sides of the fabric, taking as small of a stitch as possible.
    • Slowly pull the thread. As you pull, a loop will form. Draw the needle through this loop, and pull the thread taut.
    • Repeat this step, taking a tiny stitch, drawing the needle through the loop, and pulling taut.
    • Ensure that the stitches are tight, and cut any excess threads.
    Frag FixBot
Ziellinie
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 46
Letzte 30 Tage: 245
Insgesamt: 14,923
