Einleitung
Patch jeans with a sew-on patch. This technique is also applicable for adding patches to bags, bandanas, and boy-scout uniforms. Patches can also be sewn on by hand.
For replacement parts or further assistance, contact Patagonia Customer Service.
Was du brauchst
Examine the damage. Clip any loose threads and remove any debris from the tear.
Grab a trendy patch.
Position the patch over the hole.
Any patch you use should overlap the damage by at least 1/8".
Slide the jeans into the sewing machine, positioning the needle over the edge of the patch.
Lower the pressor foot.
Sew along the edge of the patch.
Remove the pins before you get to them.
Continue sewing around the patch, lifting the pressor foot to turn at corners of the patch.
When you come all the way around, overlap the first two or three stitches.
Lift the needle and pressor foot.
Slide the jeans out of the sewing machine.
Clip any threads, and admire your work.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
