Zum Hauptinhalt wechseln
Shark AI Ultra AV2511AE Drive Wheel Motor Replacement
Was du brauchst
  1. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement, Drive Wheel Motor: Schritt 1, Bild 1 von 2 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement, Drive Wheel Motor: Schritt 1, Bild 2 von 2
    • Put the device with the wheel side up.
    • Remove the five 11 mm screws surrounding the drive wheel using a Torx TR15 screwdriver.
    • Gently pull the wheel assembly out.
    • Make sure to pull lightly on the wheel assembly to ensure wires do not rip apart.
  2. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: Schritt 2, Bild 1 von 2 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: Schritt 2, Bild 2 von 2
    • Separate the wire connector from the wheel assembly using an opening tool.
  3. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: Schritt 3, Bild 1 von 2 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: Schritt 3, Bild 2 von 2
    • Remove the spring from the wheel assembly.
  4. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: Schritt 4, Bild 1 von 2 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: Schritt 4, Bild 2 von 2
    • Remove the four 7 mm screws around the gearbox using a Torx TR8 screwdriver.
    • Remove the gearbox cover.
    • Be careful about handling the wheel assembly with the gearbox exposed. Debris can enter in and the gears may fall out.
  5. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: Schritt 5, Bild 1 von 3 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: Schritt 5, Bild 2 von 3 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: Schritt 5, Bild 3 von 3
    • If holding the motor vertical, it may fall out once the screws are removed.
    • Using the Phillips #0 screwdriver, remove the two 4mm screws holding the motor to the gearbox.
    • Remove the motor.
Abschluss
Utah Tech University, Team 1-3, McMurrin Fall 2023 Mitglied von Utah Tech University, Team 1-3, McMurrin Fall 2023
UTAHTECH-MCMURRIN-F23S1G3
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 28
Insgesamt: 250
