Einleitung
This guide for the Shark AI Ultra AV2511AE will show the steps to successfully replace the side brush motors. These steps will need to be completed if the side brushes are not properly working. The purpose of the side brushes is to scoop up any debris into the vacuum dust bin.
Was du brauchst
Orient the device upside-down.
Holding the brush with two fingers firmly, use a Torx TR9 screwdriver to remove the 5 mm screw.
Fast fertig!
Abschluss
