Zum Hauptinhalt wechseln
Shark Flex DuoClean LED Headlight Replacement
Was du brauchst
  1. Shark Flex DuoClean LED Headlight Replacement, Garage Door: Schritt 1, Bild 1 von 2 Shark Flex DuoClean LED Headlight Replacement, Garage Door: Schritt 1, Bild 2 von 2
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean LED Headlight Replacement, Side Component: Schritt 2, Bild 1 von 2 Shark Flex DuoClean LED Headlight Replacement, Side Component: Schritt 2, Bild 2 von 2
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
  3. Shark Flex DuoClean LED Headlight Replacement: Schritt 3, Bild 1 von 2 Shark Flex DuoClean LED Headlight Replacement: Schritt 3, Bild 2 von 2
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
  4. Shark Flex DuoClean LED Headlight Replacement: Schritt 4, Bild 1 von 1
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
  5. Shark Flex DuoClean LED Headlight Replacement: Schritt 5, Bild 1 von 1
    • Remove the side component with your hands.
  6. Shark Flex DuoClean LED Headlight Replacement, LED Headlight: Schritt 6, Bild 1 von 1
  7. Shark Flex DuoClean LED Headlight Replacement: Schritt 7, Bild 1 von 2 Shark Flex DuoClean LED Headlight Replacement: Schritt 7, Bild 2 von 2
    • Use the nylon spudger to pry the gold, plastic cover off of the headlights.
    • Prying off the cover too aggressively may cause it to break.
  8. Shark Flex DuoClean LED Headlight Replacement: Schritt 8, Bild 1 von 2 Shark Flex DuoClean LED Headlight Replacement: Schritt 8, Bild 2 von 2
  9. Shark Flex DuoClean LED Headlight Replacement: Schritt 9, Bild 1 von 2 Shark Flex DuoClean LED Headlight Replacement: Schritt 9, Bild 2 von 2
    • Use the metal spudger to pry off the clear, plastic cover on the LEDs.
    • Prying the cover off too aggressively may cause it to break.
  10. Shark Flex DuoClean LED Headlight Replacement: Schritt 10, Bild 1 von 1
    • Use wire cutters to detach the black cables from the LEDs on both sides.
    • Strip 1 cm off the ends of the wires, using a wire stripper.
    • Solder the exposed wires to the new LEDs.
    • Use the soldering guide in the Introduction.
Abschluss
Cal Poly, Team S17-G5, White Fall 2018 Mitglied von Cal Poly, Team S17-G5, White Fall 2018
CPSU-WHITE-F18S17G5
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 1,362
