Einleitung
The motherboard controls the power to the vacuum. If your vacuum is not turning on, your motherboard may need to be replaced. Follow these instructions to access the motherboard for replacement.
Was du brauchst
Lift the latches on both sides of the vacuum to release the dust canister.
Remove the dust canister from the vacuum by lifting it up.
Lay down the vacuum to access the bottom panel of the roller brush compartment.
Using the metal spudger, pry the two small wheels located at the two bottom corners of the vacuum to remove them.
Remove the eight 19mm Phillips #2 screws from the plastic cover.
Remove the two 14 mm Phillips #2 screws from the upper section of the plastic cover.
Gently pull the grey lower part of the roller brush compartment away from the purple upper part of the compartment.
Lift up and then pull the roller belt off of the roller brush and the motor to remove it.
Disconnect the wires connecting the motherboard to the vacuum by unscrewing the twist-on wire connectors.
Desolder the wires connecting the motherboard to the motor. Get tips on how to desolder by checking out How to Solder and Desolder.
3 weitere Personen haben diese Anleitung absolviert.
5 Kommentare
Great work team!
Thanks Thomas! Your support is greatly appreciated!
Any knowledge on how to fix or replace the handle lick button. Mine won't lock and so the whole vacuum doesn't work
I have a 350 will the 352 powerhead motherboard work as a replacement as I can’t find a 305 one
I have a 350 vacume but need a replacement powerhead circuit board would the 352 work? It looks the same and it’s the same unit?
