Zum Hauptinhalt wechseln
Shark Navigator Lightweight Upright Motherboard Replacement
Was du brauchst
  1. Shark Navigator Lightweight Upright Motherboard Replacement, Head Shell: Schritt 1, Bild 1 von 2 Shark Navigator Lightweight Upright Motherboard Replacement, Head Shell: Schritt 1, Bild 2 von 2
    • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
  2. Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 2, Bild 1 von 2 Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Lay the vacuum on its side.
    • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
  3. Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Flip over the vacuum head so the brush head is facing up.
  4. Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 4, Bild 1 von 3 Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 4, Bild 2 von 3 Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
    • Repeat this for the other wheel.
  5. Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 5, Bild 1 von 2 Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the two 18mm screws with a JIS 1 screwdriver.
  6. Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 6, Bild 1 von 2 Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
  7. Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 7, Bild 1 von 2 Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
  8. Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 8, Bild 1 von 3 Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 8, Bild 2 von 3 Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
    • Prying in multiple locations may be necessary to create separation.
  9. Shark Navigator Lightweight Upright Motherboard Replacement, Motor: Schritt 9, Bild 1 von 1
    • Locate the motor on the top right corner of the vacuum head shell.
  10. Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 10, Bild 1 von 3 Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 10, Bild 2 von 3 Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Remove the belt from the motor gear by sliding the belt to the right.
  11. Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 11, Bild 1 von 3 Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 11, Bild 2 von 3 Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 11, Bild 3 von 3
    • Remove the white metal wire connector from the motor.
    • The white cable is positive.
  12. Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 12, Bild 1 von 2 Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Remove the black metal wire connector from the motor.
    • The black cable is negative.
  13. Shark Navigator Lightweight Upright Motherboard Replacement, Motherboard: Schritt 13, Bild 1 von 2 Shark Navigator Lightweight Upright Motherboard Replacement, Motherboard: Schritt 13, Bild 2 von 2
    • Remove the two 12mm screws using a JIS 1 screwdriver.
  14. Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Remove the wire housing by removing one 12mm screw using a JIS 1 screwdriver.
  15. Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 15, Bild 1 von 2 Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 15, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Lift up the wire housing from the plastic base using tweezers.
  16. Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 16, Bild 1 von 2 Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 16, Bild 2 von 2
    • Free the black and white cables that were previously attached to the motor from their slot.
  17. Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 17, Bild 1 von 2 Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 17, Bild 2 von 2
    • Free the motherboard and its connecting parts from the rest of the vacuum.
    • Turn the motherboard upside-down and spread wires out.
  18. Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 18, Bild 1 von 2 Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 18, Bild 2 von 2
    • Heat the wire connection's solder joint until the joint looks wet and liquidy.
    • While maintaining contact with the solder iron, free the wire end by pulling the wire away from the board with the tweezers.
    • For instructions on how to solder properly please refer to this soldering technique guide. Wie man Lötverbindungen herstellt und entlötet
    • Remember which cables were soldered onto where. You will have to re-solder the cables back onto the same joint.
    • Solder iron is extremely hot and should be handled with care. Always wear eye protection when soldering.
  19. Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 19, Bild 1 von 3 Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 19, Bild 2 von 3 Shark Navigator Lightweight Upright Motherboard Replacement: Schritt 19, Bild 3 von 3
    • Completely free the cable by pulling it out of the board.
    • Repeat for the remaining cables. There are 4 total.
Abschluss
Suzie
527 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S4-G6, Livingston Fall 2017 Mitglied von Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 16
Insgesamt: 1,568
