Einleitung
Use this guide to remove the motherboard. There is soldering required, so if you need assistant please read this soldering technique page.
Ersatzteile
Keine Ersatzteile angegeben.
Gently position the device so that the buttons and speakers lie face down.
Unplug the power cord from the "DC Input."
Remove the four 12mm phillips head #2 screws located along the outer edge of the white case.
Once you remove the screws, pick the device up so that the grey label on the bottom of the device faces toward you.
With your thumbs on either side of the grey label, slowly push with both thumbs until the case pops open.
Grip both sides of the top round part of the case and carefully open it like a clam. The bottom of the two halves are connected by the speaker wire. Do not separate by more than 1 centimeter.
Grip either side of the top round part of the case and carefully open the device to reveal all the hidden treasures inside!
Lay the device down, so that all the internal components are facing upwards.
Turn the device over so that the internals are facing down.
Remove the three 7mm Phillips #1 screws connecting the Zipconnect unit.
Turn the device over again so you are looking at the internals.
Remove the six 7mm Phillips #1 phillips screws attatching the Zipconnect unit to the motherboard wire and set the unit out of the way.
Disconnect the speaker wire from the motherboard by firmly griping the wires close to the connection with two fingers and pull the connector out.
Remove the two 11mm Phillips #1 screws attaching the small brown circuit board to the plastic outer case.
Also remove the four 11mm Phillips #1 screws attaching the motherboard to the plastic case.
Lift up on both the motherboard and brown circuit board which contains the light intensity dial.
Turn over the motherboard and remove the solder connecting the wide, flat, grey wire.
