Einleitung
The motherboard going bad can cause numerous problems for the device such as the the buttons not functions, the screen not working, and even cause the whole device to be defective.
Was du brauchst
Starting with the bottom left corner, press down on the plastic opening tool to unhook the latches on the inside of the device.
Unlatch the two clips located at the top of the device that hold the motherboard in place.
Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
