Einleitung
This repair guide will walk you through the primary steps of replacing the battery in the Skytex Skypad SP728.
Was du brauchst
Make sure the device is powered off
Rotate the device so the ports and screws face you
Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
Use the soldering iron and remove soldered connections to separate the wires connected to the battery from the circuit board.
Follow the link below for additional soldering information Wie man Lötverbindungen herstellt und entlötet
Using the plastic opening tool, lift up the battery from right edge and set aside.
To reassemble your device with a new battery, follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
