Zum Hauptinhalt wechseln
Slingbox SOLO DC Power Connector Replacement
Was du brauchst
  1. Slingbox SOLO DC Power Connector Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Use the plastic opening tool to remove the four rubber pads from the bottom of the device.
  2. Slingbox SOLO DC Power Connector Replacement: Schritt 2, Bild 1 von 3 Slingbox SOLO DC Power Connector Replacement: Schritt 2, Bild 2 von 3 Slingbox SOLO DC Power Connector Replacement: Schritt 2, Bild 3 von 3
    • The Slingbox has four black 5mm screws, one on each corner of the case.
    • Remove the four black 5mm screws using the PH1 screwdriver.
    • Gently pull and separate the two case covers.
  3. Slingbox SOLO DC Power Connector Replacement: Schritt 3, Bild 1 von 3 Slingbox SOLO DC Power Connector Replacement: Schritt 3, Bild 2 von 3 Slingbox SOLO DC Power Connector Replacement: Schritt 3, Bild 3 von 3
    • The motherboard has five silver 5.5mm screws connecting it to the base of the Slingbox.
    • Remove the five silver screws on the motherboard using the PH1 screwdriver.
    • Gently slide and separate the motherboard from the base.
  4. Slingbox SOLO DC Power Connector Replacement, DC Power Connector: Schritt 4, Bild 1 von 1
    • Do not touch the heated tip of the soldering iron.
    • Check this guide out to learn how to use a soldering iron.
    • Desolder all three lead prongs.
    • Gently pull the DC power connector from the motherboard.
Abschluss
To reassemble your device, follow the instructions in reverse order.
Nitin Muralidhar
222 Reputation
2 Anleitungen geschrieben
IUPUI, Team 2-2, Harley SU 2016 Mitglied von IUPUI, Team 2-2, Harley SU 2016
IUPUI-HARLEY-SU16S2G2
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 278
