Zum Hauptinhalt wechseln
Smartab STJR700 Back Camera Lens Replacement
Was du brauchst
  1. Smartab STJR700 Back Camera Lens Replacement, Back Camera Lens: Schritt 1, Bild 1 von 2 Smartab STJR700 Back Camera Lens Replacement, Back Camera Lens: Schritt 1, Bild 2 von 2
    • The first thing you want to do is remove the back cover. Using your screwdriver in your tool kit, start by removing the screws on the back of the Smartab.
    • After the screws are removed, carefully remove the cover to expose the inside of the tablet.
  2. Smartab STJR700 Back Camera Lens Replacement: Schritt 2, Bild 1 von 3 Smartab STJR700 Back Camera Lens Replacement: Schritt 2, Bild 2 von 3 Smartab STJR700 Back Camera Lens Replacement: Schritt 2, Bild 3 von 3
    • When you open the tablet, you will see the several components that help it to function.
    • While observing the other components, you will see that the camera is kept in place by screws. The digitizer, is held in place using black tape.
    • When the tape is peeled back, you see that the digitizer is also connected to the motherboard.
  3. Smartab STJR700 Back Camera Lens Replacement: Schritt 3, Bild 1 von 3 Smartab STJR700 Back Camera Lens Replacement: Schritt 3, Bild 2 von 3 Smartab STJR700 Back Camera Lens Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Using the same screwdriver, begin to unscrew the camera from the tablet.
    • Using tweezers from your tool kit, begin to remove the digitizer from the hard drive.
    • Once that is removed, and the camera is unscrewed, you can remove them completely from the tablet.
    • Add in replacement parts using a reverse method. You will need a soldering tool to reconnect the digitizer.
    • To change the actual camera lens follow the following steps.
    • Remove the broken glass using tweezers. If your new lens has adhesive on it, ensure you remove all the old adhesive from the frame so the lens doesn't stick out unnecessarily and so it forms a tighter seal.
    • Once the glass is removed, you can start to place the new camera lens. Peel off the upper film and assemble the glass with the ring.
Abschluss
Fatu Woodson
101 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S3-G4, Botvin Spring 2017 Mitglied von UMass Dartmouth, Team S3-G4, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 363
