Zum Hauptinhalt wechseln
Solio Rocsta Charging Cable Replacement
Was du brauchst
  1. Solio Rocsta Charging Cable Replacement, Charging Cable: Schritt 1, Bild 1 von 2 Solio Rocsta Charging Cable Replacement, Charging Cable: Schritt 1, Bild 2 von 2
    • Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
  2. Solio Rocsta Charging Cable Replacement: Schritt 2, Bild 1 von 2 Solio Rocsta Charging Cable Replacement: Schritt 2, Bild 2 von 2
    • Remove top cover.
    • Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire.
  3. Solio Rocsta Charging Cable Replacement: Schritt 3, Bild 1 von 1
    • Using the spudger, pry the battery off the back cover.
  4. Solio Rocsta Charging Cable Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the 5.66 mm screws attaching the circuit board to the case.
  5. Solio Rocsta Charging Cable Replacement: Schritt 5, Bild 1 von 1
    • With the circuit board flipped, locate the battery connector.
    • Hold the component attached to the circuit board the battery is connected to and wiggle the cable out.
  6. Solio Rocsta Charging Cable Replacement: Schritt 6, Bild 1 von 1
    • With a Soldering Iron, desolder the four cables that connect the charging cable to the circuit board.
    • The power cable is a series of four cables. Make note of each cable placement for easy resoldering.
    • For more information on how to solder and desolder connections, please visit this guide.
Abschluss
David Vazquez
577 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S13-G13, Cagle Fall 2017 Mitglied von USF Tampa, Team S13-G13, Cagle Fall 2017
USFT-CAGLE-F17S13G13
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 210
