Zum Hauptinhalt wechseln
Sonos One Mid-Woofer Diaphragm Repair/ Replacement
Was du brauchst
  1. Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Protective Cover: Schritt 1, Bild 1 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Protective Cover: Schritt 1, Bild 2 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Protective Cover: Schritt 1, Bild 3 von 3
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
  2. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 2, Bild 1 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 2, Bild 2 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 2, Bild 3 von 3
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
  3. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 3, Bild 1 von 2 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 3, Bild 2 von 2
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
  4. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 4, Bild 1 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 4, Bild 2 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 4, Bild 3 von 3
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
  5. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 5, Bild 1 von 2 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 5, Bild 2 von 2
    • Slide the protective cover upwards to remove.
  6. Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Control Panel & Microphone: Schritt 6, Bild 1 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Control Panel & Microphone: Schritt 6, Bild 2 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Control Panel & Microphone: Schritt 6, Bild 3 von 3
    • Use the pointed end of a spudger to remove the covers that hide the screws.
    • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
  7. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 7, Bild 1 von 2 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 7, Bild 2 von 2
    • With the front of the unit facing you, lift the control panel up using your thumbs.
    • There's a ribbon cable attaching the control panel to the speaker so work slowly.
  8. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 8, Bild 1 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 8, Bild 2 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 8, Bild 3 von 3
    • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
    • Pull the control panel ribbon cable out of its socket.
  9. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 9, Bild 1 von 2 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 9, Bild 2 von 2
    • Pull the control panel away from the speaker to separate.
  10. Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Power Adapter Receptacle: Schritt 10, Bild 1 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Power Adapter Receptacle: Schritt 10, Bild 2 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Power Adapter Receptacle: Schritt 10, Bild 3 von 3
    • Remove the six 9mm Torx T8 screws from the motherboard panel.
  11. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 11, Bild 1 von 2 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 11, Bild 2 von 2
    • Using a plastic opening tool, separate the motherboard from the speaker.
  12. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 12, Bild 1 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 12, Bild 2 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 12, Bild 3 von 3
    • Using your thumb, disconnect the speaker cable from the motherboard.
  13. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 13, Bild 1 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 13, Bild 2 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 13, Bild 3 von 3
    • Disconnect the power adapter plug from the motherboard using your thumb.
  14. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 14, Bild 1 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 14, Bild 2 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 14, Bild 3 von 3
    • Using the pointed end of the spudger, disconnect the red, green, and yellow cables connecting the WiFi transmitter/receiver.
  15. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 15, Bild 1 von 2 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 15, Bild 2 von 2
    • Remove the motherboard panel from the speaker housing.
  16. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 16, Bild 1 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 16, Bild 2 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 16, Bild 3 von 3
    • The woofer is highly magnetic, making removal of the metal screws sometimes difficult.
    • Remove the two 9mm Torx T8 screws from the power adapter plug.
    • Remove the power adapter receptacle from its housing slot.
  17. Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Tweeter Diaphragm: Schritt 17, Bild 1 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Tweeter Diaphragm: Schritt 17, Bild 2 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Tweeter Diaphragm: Schritt 17, Bild 3 von 3
    • Disconnect the woofer cables.
    • If removing the tabs is difficult, the flat end of the spudger may be used to depress the middle tab and then the tab may be pulled to disconnect.
  18. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 18, Bild 1 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 18, Bild 2 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 18, Bild 3 von 3
    • Disconnect the cables from the tweeter.
  19. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 19, Bild 1 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 19, Bild 2 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 19, Bild 3 von 3
    • Remove the four 10mm Torx T10 screws from the tweeter.
    • Remove the tweeter from the speaker housing.
  20. Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Woofer Diaphragm: Schritt 20, Bild 1 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Woofer Diaphragm: Schritt 20, Bild 2 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Woofer Diaphragm: Schritt 20, Bild 3 von 3
    • Remove the four 10mm Torx T10 screws from the woofer.
  21. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 21, Bild 1 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 21, Bild 2 von 3 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: Schritt 21, Bild 3 von 3
    • The woofer is snuggly fit into the frame socket, some careful manipulation is required to remove the woofer from the housing.
    • Remove the woofer from the speaker housing.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S2-G1, Nance Spring 2018 Mitglied von USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 Mitglieder
14 Anleitungen geschrieben
6 Kommentare zur Anleitung
Any suggestion on where to buy these woofers (in Europe/Belgium)?
KimVM - Antwort Teilen
@mglowa Any idea where to buy a replacement woofer pictured above? Or what to look for, an equivalent perhaps?
Bryan Martinez - Antwort Teilen
This is the link to the replacement woofer that I used to repair my Sonos One in August 2024: https://www.aliexpress.com/item/10050071...
robotedward - Antwort Teilen
"SOTAMIA 1Pcs 3.5 Inch Midrange Woofer Speaker 4 Ohm 35W Bass Loudspeaker Aluminum Basin Hifi Music Sound Speaker Audio For SONOS"
56mm high,
75mm distance between adjacent screw holes
105mm diagonal distance between non-adjacent screw holes
97mm width of outer casing
Great guide - replaced the subwoofer using the part above. A few things to note:
Step 13: my unit didn't have an power adapter plug; wires soldered onto board
Step 14:my unit had hardened glue spread on the yellow/red/green cables making removal impossible.
There was no need to remove the tweeter to replace the woofer (steps 18/19).
markrwhite - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 60
Letzte 30 Tage: 187
Insgesamt: 9,239
