Einleitung
This guide is for the replacement of tweeter diaphragm for the Sonos One.
Important: Accessing the internals of the Sonos One will void the factory warranty and make the unit rejected for factory repair, even if warranty is expired.
Was du brauchst
Disconnect all power cords.
Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
With the front of the unit facing you, lift the control panel up using your thumbs.
Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
Pull the control panel ribbon cable out of its socket.
Remove the six 9mm Torx T8 screws from the motherboard panel.
Using the pointed end of the spudger, disconnect the red, green, and yellow cables connecting the WiFi transmitter/receiver.
Remove the two 9mm Torx T8 screws from the power adapter plug.
Remove the power adapter receptacle from its housing slot.
Remove the four 10mm Torx T10 screws from the tweeter.
Remove the tweeter from the speaker housing.
