Einleitung
This guide shows how to replace the IR receiver of a Sonos Playbase, which receives signals from the television or other IR remote.
Was du brauchst
Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
Disconnect the main speaker array from the main board, by pinching and and pulling the tab out.
Remove the side speakers from the green printed circuit board (PCB) running along the top of the main speaker array by pinching and pulling out the connector.
Remove the two 16mm T-20 screws located on both sides of the main speaker array by turning counter-clockwise.
Lift the main speaker array to reveal the IR receiver underneath.
Remove the three 11 mm T-5 screws by turning counter-clockwise.
