Einleitung
This guide will be showing you how to get into the back of the LCD screen on the Sony Alpha 5100 (ILCE-5100/5100L). This guide will help if you are having trouble with the camera screen not working. Since we are exposing the electronics underneath the screen, do not expose the inside to water.
Was du brauchst
Flip the LCD screen so that you have access to the back of the screen. The front of the screen should be facing the direction that the lens is facing.
Remove the two 2mm Phillips #00 screws on the back of the screen.
Remove the two 2mm Phillips #00 screws on the top of the LCD screen.
3 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Hello, thank you for this but it’s only half the steps, how to remove the LCD and touch screen after step 5? Something else is holding it in place. Can lift the outer edge a little only. Possibly it is glue or tape? My touchscreen is always active and focus rectangle moving around the lower part of screen. Can touch screen and it will go there but soon moves back to lower area.
Thank you.
