Zum Hauptinhalt wechseln
Sony BDP-BX510 Wi-Fi Module Replacement
Was du brauchst
  1. Sony BDP-BX510 Wi-Fi Module Replacement, Outer Cover: Schritt 1, Bild 1 von 1
    • Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
  2. Sony BDP-BX510 Wi-Fi Module Replacement: Schritt 2, Bild 1 von 2 Sony BDP-BX510 Wi-Fi Module Replacement: Schritt 2, Bild 2 von 2
    • To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
    • Apply slightly more pressure to the left side until it unhooks then unhook the right side.
    • Close the disk tray by pressing the eject button again, then power off the device and unplug it.
    • Do not use too much force to remove the tray cover as you may break it.
  3. Sony BDP-BX510 Wi-Fi Module Replacement: Schritt 3, Bild 1 von 2 Sony BDP-BX510 Wi-Fi Module Replacement: Schritt 3, Bild 2 von 2
    • Turn to the back of the device.
    • Remove the two 7mm Phillips #2 screws.
    • Slide the two plastic covers on both sides of the device towards the back of the device to remove them.
  4. Sony BDP-BX510 Wi-Fi Module Replacement: Schritt 4, Bild 1 von 3 Sony BDP-BX510 Wi-Fi Module Replacement: Schritt 4, Bild 2 von 3 Sony BDP-BX510 Wi-Fi Module Replacement: Schritt 4, Bild 3 von 3
    • Turn the device so you can see the bottom.
    • Unclip the three black plastic clips on the bottom of the device.
    • Unclip one clip on each side of the device.
  5. Sony BDP-BX510 Wi-Fi Module Replacement: Schritt 5, Bild 1 von 1
    • Slide the cover forward to remove.
  6. Sony BDP-BX510 Wi-Fi Module Replacement, Port Board: Schritt 6, Bild 1 von 1
    • Find the large ribbon cable that connects the port board to the motherboard.
    • Carefully pull directly upwards to disconnect the cable.
  7. Sony BDP-BX510 Wi-Fi Module Replacement: Schritt 7, Bild 1 von 1
    • Using the Phillips #1 screwdriver, remove the 5mm screwdriver attached to the port board.
  8. Sony BDP-BX510 Wi-Fi Module Replacement: Schritt 8, Bild 1 von 1
    • Unclip the metal piece on the lower right corner by gently lifting it up.
  9. Sony BDP-BX510 Wi-Fi Module Replacement: Schritt 9, Bild 1 von 1
    • Remove the port board by simply pulling it away from the device.
  10. Sony BDP-BX510 Wi-Fi Module Replacement, Wi-Fi Module: Schritt 10, Bild 1 von 1
    • Pull the cable that attaches the Wi-Fi module to the motherboard.
    • The cable will be hard to remove, so pull hard but carefully.
  11. Sony BDP-BX510 Wi-Fi Module Replacement: Schritt 11, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the single 5mm screw that holds Wi-Fi module to the device.
  12. Sony BDP-BX510 Wi-Fi Module Replacement: Schritt 12, Bild 1 von 1
    • Carefully remove the Wi-Fi module from the device.
    • Avoid getting fingerprints on the module.
Abschluss
Niki Ngosi
375 Reputation
3 Anleitungen geschrieben
York University, Team S1-G10, Woodhouse Winter 2020 Mitglied von York University, Team S1-G10, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G10
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 273
