Zum Hauptinhalt wechseln
Sony BDP-S3500 Disk Drive Replacement
Was du brauchst
  1. Sony BDP-S3500 Disk Drive Replacement, Front Panel: Schritt 1, Bild 1 von 2 Sony BDP-S3500 Disk Drive Replacement, Front Panel: Schritt 1, Bild 2 von 2
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
  2. Sony BDP-S3500 Disk Drive Replacement: Schritt 2, Bild 1 von 1
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
  3. Sony BDP-S3500 Disk Drive Replacement: Schritt 3, Bild 1 von 2 Sony BDP-S3500 Disk Drive Replacement: Schritt 3, Bild 2 von 2
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
  4. Sony BDP-S3500 Disk Drive Replacement, Disk Drive: Schritt 4, Bild 1 von 2 Sony BDP-S3500 Disk Drive Replacement, Disk Drive: Schritt 4, Bild 2 von 2
    • Remove the three ribbon cables by gently pulling the cables out of each connector.
    • Be sure to only handle the circuit board from the edges so that the PCB is not damaged.
  5. Sony BDP-S3500 Disk Drive Replacement: Schritt 5, Bild 1 von 2 Sony BDP-S3500 Disk Drive Replacement: Schritt 5, Bild 2 von 2
    • Use a Phillips #2 screwdriver to remove the two 9mm screws that are holding the disk drive in place.
  6. Sony BDP-S3500 Disk Drive Replacement: Schritt 6, Bild 1 von 2 Sony BDP-S3500 Disk Drive Replacement: Schritt 6, Bild 2 von 2
    • Carefully lift and slide the disk drive out of the casing.
Abschluss
V W
197 Reputation
1 Anleitung geschrieben
York University, Team S8-G4, Turner Winter 2020 Mitglied von York University, Team S8-G4, Turner Winter 2020
YORK-TURNER-W20S8G4
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Hello, great guide thank you. How do you go about finding the correct replacement drive?
Andy Day - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 369
