Zum Hauptinhalt wechseln
Sony Cyber-Shot DSC-TX9 Lens Replacement
Was du brauchst
  1. Sony Cyber-Shot DSC-TX9 Lens Replacement, Prerequisites Only: Schritt 1, Bild 1 von 3 Sony Cyber-Shot DSC-TX9 Lens Replacement, Prerequisites Only: Schritt 1, Bild 2 von 3 Sony Cyber-Shot DSC-TX9 Lens Replacement, Prerequisites Only: Schritt 1, Bild 3 von 3
    • Use a Phillips #0 screwdriver to unscrew the six 2mm screws on the outer case of the camera.
    • If there is a battery or SD card inside remove before beginning the process.
  2. Sony Cyber-Shot DSC-TX9 Lens Replacement: Schritt 2, Bild 1 von 2 Sony Cyber-Shot DSC-TX9 Lens Replacement: Schritt 2, Bild 2 von 2
    • Use your hands or a Spudger to Pull off the front cover of the camera.
    • If the casing is not coming apart easily, do not force it.
  3. Sony Cyber-Shot DSC-TX9 Lens Replacement: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Remove the protective black cover layer with your hands and set it aside.
    • The use of tweezers may be necessary if the cover is difficult to remove.
  4. Sony Cyber-Shot DSC-TX9 Lens Replacement: Schritt 4, Bild 1 von 2 Sony Cyber-Shot DSC-TX9 Lens Replacement: Schritt 4, Bild 2 von 2
    • The ZIF connector can be removed by flipping the small black holder into the upright position and then sliding the ribbon cable out carefully.
    • Once this has been done, use tweezers to unplug the flat topped connector for the lens’ circuit board from the motherboard.
    • DO NOT force the ribbon cables or they will rip.
    • Refer to the (Erkennen und Trennen von Kabelverbindern) page for assistance.
  5. Sony Cyber-Shot DSC-TX9 Lens Replacement, Lens: Schritt 5, Bild 1 von 1
    • Using the tweezers carefully remove the broken/damaged lens with its attached circuit board
Abschluss
robert.oliver6
101 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S4-G3, Julie Spring 2017 Mitglied von UMass Dartmouth, Team S4-G3, Julie Spring 2017
UMASSD-JULIE-S17S4G3
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 454
