Zum Hauptinhalt wechseln
Sony Cyber-Shot DSC-W830 LCD Replacement
Was du brauchst
  1. Sony Cyber-Shot DSC-W830 LCD Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 LCD Replacement: Schritt 2, Bild 1 von 1
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 LCD Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: Schritt 4, Bild 1 von 3 Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: Schritt 4, Bild 2 von 3 Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: Schritt 4, Bild 3 von 3
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 LCD Replacement: Schritt 5, Bild 1 von 3 Sony Cyber-Shot DSC-W830 LCD Replacement: Schritt 5, Bild 2 von 3 Sony Cyber-Shot DSC-W830 LCD Replacement: Schritt 5, Bild 3 von 3
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
  6. Sony Cyber-Shot DSC-W830 LCD Replacement: Schritt 6, Bild 1 von 3 Sony Cyber-Shot DSC-W830 LCD Replacement: Schritt 6, Bild 2 von 3 Sony Cyber-Shot DSC-W830 LCD Replacement: Schritt 6, Bild 3 von 3
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
  7. Sony Cyber-Shot DSC-W830 LCD Replacement, Button Board: Schritt 7, Bild 1 von 2 Sony Cyber-Shot DSC-W830 LCD Replacement, Button Board: Schritt 7, Bild 2 von 2
    • Gently release the button board from the clips.
    • Be careful when lifting the button board; the ribbon cable will still be attached.
  8. Sony Cyber-Shot DSC-W830 LCD Replacement: Schritt 8, Bild 1 von 2 Sony Cyber-Shot DSC-W830 LCD Replacement: Schritt 8, Bild 2 von 2
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
  9. Sony Cyber-Shot DSC-W830 LCD Replacement, LCD: Schritt 9, Bild 1 von 2 Sony Cyber-Shot DSC-W830 LCD Replacement, LCD: Schritt 9, Bild 2 von 2
    • Push the bottom right corner of the LCD screen out and slide it to the right to release it from the clips.
    • Be careful when lifting the LCD screen; the ribbon cable will still be attached.
  10. Sony Cyber-Shot DSC-W830 LCD Replacement: Schritt 10, Bild 1 von 2 Sony Cyber-Shot DSC-W830 LCD Replacement: Schritt 10, Bild 2 von 2
    • Grasp the no-fuss ribbon cable and gently pull it out from the motherboard.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 17-1, Blackwell Fall 2016 Mitglied von USF Tampa, Team 17-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G1
4 Mitglieder
6 Anleitungen geschrieben
5 Kommentare
hii
plaz help me
tajbhatnagar - Antwort
Sony Cyber-Shot DSC-W830 LCD ……WowObjects LCD Display Screen For SONY DSC-W150 same hai ya different hai
Hi I need a one DSC w810 display how much. ?
How can contact you ?
Tamil Varshitha - Antwort
Sony dsc s2000 model camera need
Display & lens unit
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 13
Letzte 30 Tage: 40
Insgesamt: 4,194
