Zum Hauptinhalt wechseln
Einleitung
This installation guide allows you to remove the power supply circuit board and power cable.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player. One 3/16" screw on the right side of the DVD player.
    • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
    • One 3/16" screw on the right side of the DVD player.
    • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
    • Three 3/16" screws on the back of the DVD player.
  2. Slide the cover away from the front of the DVD player until it is off. Slide the cover away from the front of the DVD player until it is off.
    • Slide the cover away from the front of the DVD player until it is off.
  3. Remove the blue tape from the processing board by gently pulling upward.
    • Remove the blue tape from the processing board by gently pulling upward.
  4. Use the tweezers to remove the four sets of wires connected to the processing board.  Start with the cord located in front of the row of three cords. The wires may be difficult to remove.  Wiggling them while lifting them up may help remove them.
    • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
    • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
  5. Handle the processing board with care.  It is fragile.
    • Handle the processing board with care. It is fragile.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
  6. Orient the DVD player so that you are facing the video and audio jacks.
    • Orient the DVD player so that you are facing the video and audio jacks.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
    • The processing board is now free to be removed and replaced.
  7. Caution: The circuit board contains capacitors (they look like cylinders) that can shock you if they discharge. Be careful not to touch them as you work. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Caution: The circuit board contains capacitors (they look like cylinders) that can shock you if they discharge. Be careful not to touch them as you work. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Unhook the power supply connector from the power supply board by pressing down on the small latch.
  8. Orient the DVD player so the back of the DVD player is opposite of you.
    • Orient the DVD player so the back of the DVD player is opposite of you.
    • Unscrew the two #1 Phillips screws (silver, 3/16") that attach the power supply circuit board to the bottom of the DVD player.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Brian Hua
70 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 5-17, Forte Winter 2013 Mitglied von Cal Poly, Team 5-17, Forte Winter 2013
CPSU-FORTE-W13S5G17
5 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 3
Letzten 30 Tage: 34
Insgesamt: 7,528
