Zum Hauptinhalt wechseln
Sony FDL-220R Watchman Antenna Replacement
Was du brauchst
  1. Sony FDL-220R Watchman Antenna Replacement, Remove battery cover and batteries: Schritt 1, Bild 1 von 2 Sony FDL-220R Watchman Antenna Replacement, Remove battery cover and batteries: Schritt 1, Bild 2 von 2
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Antenna Replacement, Remove screws: Schritt 2, Bild 1 von 2 Sony FDL-220R Watchman Antenna Replacement, Remove screws: Schritt 2, Bild 2 von 2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  3. Sony FDL-220R Watchman Antenna Replacement, Remove back casing: Schritt 3, Bild 1 von 2 Sony FDL-220R Watchman Antenna Replacement, Remove back casing: Schritt 3, Bild 2 von 2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  4. Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: Schritt 4, Bild 1 von 3 Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: Schritt 4, Bild 2 von 3 Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: Schritt 4, Bild 3 von 3
    • Locate the two metal tabs which are meant to hold the antenna in place.
    • Pry back the metal tabs with a spudger.
    • Hook the antenna into the metal tab.
    • Ensure that the antenna is fully enclosed in the metal tab.
Abschluss
Sam Putnam
484 Reputation
4 Anleitungen geschrieben
Baylor, Team 4-5, Williams Fall 2014 Mitglied von Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 19
Insgesamt: 462
