Zum Hauptinhalt wechseln
Sony FDL-220R Watchman Speaker Replacement
Was du brauchst
  1. Sony FDL-220R Watchman Speaker Replacement, Remove battery cover and batteries: Schritt 1, Bild 1 von 2 Sony FDL-220R Watchman Speaker Replacement, Remove battery cover and batteries: Schritt 1, Bild 2 von 2
    • Press down on the textured area and push toward the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Speaker Replacement, Remove screws: Schritt 2, Bild 1 von 2 Sony FDL-220R Watchman Speaker Replacement, Remove screws: Schritt 2, Bild 2 von 2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  3. Sony FDL-220R Watchman Speaker Replacement, Remove back casing: Schritt 3, Bild 1 von 2 Sony FDL-220R Watchman Speaker Replacement, Remove back casing: Schritt 3, Bild 2 von 2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  4. Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: Schritt 4, Bild 1 von 3 Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: Schritt 4, Bild 2 von 3 Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: Schritt 4, Bild 3 von 3
    • Carefully grasp the entire circuit board.
    • Pull the circuit board off of the device's plastic casing.
  5. Sony FDL-220R Watchman Speaker Replacement, Remove speaker: Schritt 5, Bild 1 von 3 Sony FDL-220R Watchman Speaker Replacement, Remove speaker: Schritt 5, Bild 2 von 3 Sony FDL-220R Watchman Speaker Replacement, Remove speaker: Schritt 5, Bild 3 von 3
    • Locate the mono-speaker on the device.
    • Locate the two through-hole contacts to the right of the speaker.
    • Touch a soldering iron to the two through-hole contacts.
    • While the solder is hot, pull down on the wire with tweezers.
    • It may be helpful to remove excess solder with a solder wick or sucker.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Sam Putnam
484 Reputation
4 Anleitungen geschrieben
Baylor, Team 4-5, Williams Fall 2014 Mitglied von Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 9
Insgesamt: 289
