Zum Hauptinhalt wechseln
Sony H.ear On 2 Motherboard Replacement
Was du brauchst
  1. Sony H.ear On 2 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 2 Sony H.ear On 2 Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Start on the left side by using the plastic opening tool in the crease between the ear cup and plastic. Gently apply pressure until it separates.
    • Do not force any parts off as the plastic holders may snap off if too much pressure is applied.
  2. Sony H.ear On 2 Motherboard Replacement: Schritt 2, Bild 1 von 2 Sony H.ear On 2 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use the JIS #00 Screwdriver to remove the 2 6.4mm screws holding in the motherboard.
  3. Sony H.ear On 2 Motherboard Replacement: Schritt 3, Bild 1 von 3 Sony H.ear On 2 Motherboard Replacement: Schritt 3, Bild 2 von 3 Sony H.ear On 2 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • De-solder all 18 wire-connections on the motherboard.
    • Record wire positions on board for proper connections when re-soldering the replacement board.
    • Do not overheat joints while de-soldering to prevent board damage.
    • Please see Wie man Lötverbindungen herstellt und entlötet for help on soldering and desoldering connections.
  4. Sony H.ear On 2 Motherboard Replacement: Schritt 4, Bild 1 von 2 Sony H.ear On 2 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the white ribbon cable by gently tugging on the white connector while holding the motherboard carefully in place.
  5. Sony H.ear On 2 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Gently remove the old motherboard from the bracket assembly and replace and resolder motherboard.
Abschluss
Michael Long
131 Reputation
1 Anleitung geschrieben
Cal Poly, Team S9-G11, Maness Spring 2019 Mitglied von Cal Poly, Team S9-G11, Maness Spring 2019
CPSU-MANESS-S19S9G11
5 Mitglieder
16 Anleitungen geschrieben
Ein Kommentar
where can i find a replacement motherboard for these headphones?
MTL - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 25
Insgesamt: 1,547
