Einleitung
This guide will teach you step by step how to replace your LCD screen.
Was du brauchst
Use a Phillips #00 screwdriver to remove the four (4) screws on the back of the device.
If the screws strips or is previously stripped, refer to the stripped screw repair guide.
Battery is the rectangular and silver object in the center of device.
Remove battery with finger by prying at the rear.
If unable to remove battery, pry out using spudger.
Unscrew the 3 (three) screws holding the bracket in place.
Then remove the bracket by prying one end up.
Remove motherboard from the device by pulling upward gently, with fingers or tweezers.
Gently push out on these two clips holding the LCD to the motherboard
Once you have the first two off, ever so carefully, push the LCD towards the remaining two clips.
Undo the ribbon cable attached between the motherboard and screen by prying up black tab which holds the cable, using spudger. (See pictures)
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
4 Kommentare
Hi
I cant find an replacement lcd.
Could anybody help me where to get one?
Cheers
Sven
any link to the replacement LCD please?
