Zum Hauptinhalt wechseln
Sony RM-LVR1 Motherboard Replacement
Was du brauchst
    1. Sony RM-LVR1 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
      • Use a Phillips #00 screwdriver to remove the four (4) screws on the back of the device.
      • If the screws strips or is previously stripped, refer to the stripped screw repair guide.
      Frag FixBot
      Kommentar hinzufügen
    2. Sony RM-LVR1 Motherboard Replacement: Schritt 2, Bild 1 von 1
      • Battery is the rectangular and silver object in the center of device.
      • Remove battery with finger by prying at the rear.
      • If unable to remove battery, pry out using spudger.
      Frag FixBot
    1. Sony RM-LVR1 Motherboard Replacement, LCD Screen: Schritt 3, Bild 1 von 2 Sony RM-LVR1 Motherboard Replacement, LCD Screen: Schritt 3, Bild 2 von 2
      • Unscrew the 3 (three) screws holding the bracket in place.
      • Then remove the bracket by prying one end up.
      • Do not rip the ribbon cable connecting the bracket to the motherboard.
      Frag FixBot
    2. Sony RM-LVR1 Motherboard Replacement: Schritt 4, Bild 1 von 1
      In diesem Schritt verwendetes Werkzeug:
      • With tweezers, unplug the ribbon cable from the white connector.
      Frag FixBot
    3. Sony RM-LVR1 Motherboard Replacement: Schritt 5, Bild 1 von 1
      • Remove motherboard from the device by pulling upward gently, with fingers or tweezers.
      Frag FixBot
    4. Sony RM-LVR1 Motherboard Replacement: Schritt 6, Bild 1 von 1
      • Gently push out on these two clips holding the LCD to the motherboard
      • Once you have the first two off, ever so carefully, push the LCD towards the remaining two clips.
      • There is a ribbon cable underneath the LCD connecting it to the motherboard. Avoid sharp, sudden movements to prevent it from being damged
      Frag FixBot
    5. Sony RM-LVR1 Motherboard Replacement: Schritt 7, Bild 1 von 2 Sony RM-LVR1 Motherboard Replacement: Schritt 7, Bild 2 von 2
      • Undo the ribbon cable attached between the motherboard and screen by prying up black tab which holds the cable, using spudger. (See pictures)
      Frag FixBot
    6. Sony RM-LVR1 Motherboard Replacement: Schritt 8, Bild 1 von 1
      • Remove the screen from the motherboard.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
1 Kommentar zur Anleitung
Hello
Thank you for your tutorial.
My question is about the rubber cap of the push button
Can it be changed? Spare part ?
Regards
gilbert keiser - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 25
Insgesamt: 681
