Zum Hauptinhalt wechseln
Sony SRS-XB43 Speaker Replacement
Was du brauchst
  1. Sony SRS-XB43 Speaker Replacement, Faceplate: Schritt 1, Bild 1 von 2 Sony SRS-XB43 Speaker Replacement, Faceplate: Schritt 1, Bild 2 von 2
    • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
    • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
    • Fully open the hinged mesh cover and pry it off the unit.
  2. Sony SRS-XB43 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Turn the speaker so the back is facing you.
    • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
    • Remove the single screw using a T8 Torx.
  3. Sony SRS-XB43 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Remove all ten screws using a Phillips #1 screwdriver.
  4. Sony SRS-XB43 Speaker Replacement: Schritt 4, Bild 1 von 2 Sony SRS-XB43 Speaker Replacement: Schritt 4, Bild 2 von 2
    • Slowly lift the speaker face off of the housing unit.
    • Unplug the six wires connecting the faceplate to the motherboard.
  5. Sony SRS-XB43 Speaker Replacement, Speaker: Schritt 5, Bild 1 von 3 Sony SRS-XB43 Speaker Replacement, Speaker: Schritt 5, Bild 2 von 3 Sony SRS-XB43 Speaker Replacement, Speaker: Schritt 5, Bild 3 von 3
    • On the face plate of the speaker, locate the black ribbon cable plugged into the green circuit board to your right.
    • Grab the ribbon cable from its base and apply a light verticle force upwards to unplug it from the PCB.
    • This step prevents the cable from getting in the way of the right speaker as it is being removed.
  6. Sony SRS-XB43 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Remove eight black 10 mm screws attached to the speaker plate using a Phillips #1 screwdriver.
  7. Sony SRS-XB43 Speaker Replacement: Schritt 7, Bild 1 von 2 Sony SRS-XB43 Speaker Replacement: Schritt 7, Bild 2 von 2
    • Remove the two individual speakers.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Bishoy Mikhail
253 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 3-5, Botvin Fall 2022 Mitglied von UMass Dartmouth, Team 3-5, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 15
Letzte 30 Tage: 53
Insgesamt: 991
