Was du brauchst
Pry the outer cover of the speaker from the body using a spudger.
Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
Fast fertig!
Abschluss
