Zum Hauptinhalt wechseln
Sony VAIO VPCEE26FX Keyboard Replacement
Was du brauchst
  1. Sony VAIO VPCEE26FX Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Sony VAIO VPCEE26FX Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Keyboard Replacement: Schritt 2, Bild 1 von 2 Sony VAIO VPCEE26FX Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 2 Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: Schritt 3, Bild 2 von 2
    • Flip the laptop back over so it is face up.
    • Open up the laptop.
  4. Sony VAIO VPCEE26FX Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Using a plastic opening tool, pry along the seam between the keyboard and case to help in separating the two.
    • Continue to lift up gently using the plastic opening tool until the keyboard begins to separate from the case.
  5. Sony VAIO VPCEE26FX Keyboard Replacement: Schritt 5, Bild 1 von 2 Sony VAIO VPCEE26FX Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Continue lifting up and moving down starting on the left side of the keyboard moving towards the right side of the computer.
  6. Sony VAIO VPCEE26FX Keyboard Replacement: Schritt 6, Bild 1 von 2 Sony VAIO VPCEE26FX Keyboard Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Carefully tilt the top of the keyboard towards you ensuring the ribbon cable is not under too much tension.
    • Use a pair of tweezers to help remove the plastic adhesive film covering the adapter/port for the ribbon cable.
  7. Sony VAIO VPCEE26FX Keyboard Replacement: Schritt 7, Bild 1 von 1
  8. Sony VAIO VPCEE26FX Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Lift the keyboard up and away from the computer.
Abschluss
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 Mitglied von UMass Dartmouth, Team S2-G3, Bailey Spring 2019
UMASSD-BAILEY-S19S2G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 1,194
