Zum Hauptinhalt wechseln
Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement
Was du brauchst
  1. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Back Cover: Schritt 1, Bild 1 von 2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: Schritt 2, Bild 1 von 2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: Schritt 2, Bild 2 von 2
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: Schritt 3, Bild 1 von 1
    • Lift off back cover to access inner components of computer.
  4. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Fan: Schritt 4, Bild 1 von 2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Fan: Schritt 4, Bild 2 von 2
    • Remove the three 1mm Phillips #0 screws surrounding the fan.
    • Loosen the three 1mm Phillips #0 screws. These screws will stay captive to the heatsink.
  5. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: Schritt 5, Bild 1 von 3 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: Schritt 5, Bild 2 von 3 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to carefully unplug the fan connector.
  6. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Remove the Fan: Schritt 6, Bild 1 von 2 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Remove the Fan: Schritt 6, Bild 2 von 2
    • Use the Plastic Opening Tool to gently remove the heat sink and fan assembly from the computer.
    • Important: Follow the How to Apply Thermal Paste guide to replace the thermal paste before reassembling your device.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Marii
658 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 21-19, Maness Winter 2015 Mitglied von Cal Poly, Team 21-19, Maness Winter 2015
CPSU-MANESS-W15S21G19
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Could you also maybe do a tutorial on Sony Vaio Fit 13? http://www.laptoppartstore.com/replace--... Any luck figuring out how the fan may be detached and re-attached to the heatsink? Also, I notice a very specific type of taping... where can one procure those?
Abhishek D - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 4,545
